0-10vdc thermostat - Lochinvar
NYplumber
Member Posts: 503
Good afternoon wallies,
Pondering how I could get indoor temperature to control a knight boiler. Below is a link to a Honeywell thermostat that puts out a 0-10vdc signal. The control on the knight allows a 0-10 input from a BMS. Would this work?
<a href="https://estore.industrialcontrolsonline.com/default.aspx?page=item+detail&itemcode=TB7980A1006">https://estore.industrialcontrolsonline.com/default.aspx?page=item+detail&itemcode=TB7980A1006</a>
Thanks in advance.
Thanks in advance.
:NYplumber:
ZonePro thermostats
Honeywell sells them primarily for VAV applications.
Reading through https://customer.honeywell.com/resources/Techlit/TechLitDocuments/62-0000s/62-0238EF.pdf what I don't see is direct control over the PID coefficients, which I'd want to manipulate for a boiler firing rate control. It looks like the Application setting might be worth playing with.
I've been meaning to experiment with one of these on a Belimo CCV for zoning control.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
