Harmonic noise changes from Rheem gas pack
ellpats
Member Posts: 1
I have a Rheem two-stage gas pack with a scroll compressor. During the cooling cycle there is a constant and very obvious harmonic change in the noise coming from the unit.
Harmonics
How much time between normal noise and the hi/low harmonics? What is the voltage during this change ? What is the hi/low pressure? What is the SuperHeat during this change? Single phase or 3 phase?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
