To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
centro therm piping
rsdrsd Member Posts: 1
I am going to have a gas lochinvar boiler and indirect hot water heater installed to replace my 28 year old weil mcclain gas boiler.
I want the centro therm intake and exhaust to run up the current flue that was designed for the present boiler.  The flue is 8.5" away from the separate fireplace flue, in the same large, square 51" by 51" inch chimney.  Both flue chambers are tiled.
Are there concerns about the centro therm piping melting in the event of a fire in the separate fireplace flue.  Are there any other products you would recommend for venting up the flue, as I dont want pvc or any piping going out the back of the house.
 Thanks,
RSD
  • JackJack Member Posts: 889
    Your problem
    I think, is not melting the pipe. Your problem is that when you have a fire you will be pulling the smoke into the intake of the boiler, and it will not be happy. Somehow, you need to separate these two systems.
  • ChrisChris Member Posts: 3,040
    It's PLASTIC!!!
    What plastic won't melt in a fire? Agree with Jack...
    "The bitter taste of a poor installation remains much longer than the sweet taste of the lowest price."
  • papashawngopapashawngo Member Posts: 7
    good stuff
    i agree with jack as well. is it possible to vent your exhause through the flue and draw your fresh air from another location? some boilers allow for unbalanced flue installations ie triangle tube. i have been using the cenrotherm liners for over a year now and absolutely love installing them as opposed to all the other alternatives i have tried
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
