To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
ID this item.
ChuckChuck Member Posts: 83
Located in a school with a two pipe steam system (vacuum). There are more than one. I am sure I have seen it before (and probably knew what it is at some point).
  • gerry gillgerry gill Member Posts: 2,589
    if you can get me
    the info written on it i may be able to locate its patent for you.
    gwgillplumbingandheating.com
  • JStarJStar Member Posts: 2,668
    Steam
    Where is it attached to the system?
    - Joe Starosielec
    [email protected]
  • ChuckChuck Member Posts: 83
    Outside Wall
    It is on the inside of an exterior wall. There at least two in the relatively small school.
  • It looks like
    a diaphragm.
    Often wrong, never in doubt.
  • lzalza Member Posts: 40
    Piping Size?
    What size is the piping into the device?
  • gcp13gcp13 Member Posts: 117
    Sprinkler alarm?
    How do you know it is tied to the heating system.
    If its on an outside wall what's on the other side?
    I've seen alarms for sprinklers that look like this
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
