Navien NR-240-A Combustion Analysis?
SpeyFitter
Member Posts: 422
Hey guys - I've sent Navien an email about this but I want to see if anyone in here knows as well. I've read through the instruction manual included with the unit and other then recommended gas pressure range, I can not find any combustion (analysis) specifications. Anyone know? (I'm a Class 'A' Gas Fitter in BC Canada commissioning some of these at work - I WILL be putting an analyzer on it).
Analysis
I am curious if you have ever found out about the combustion readings as I am about to check one out. I too am a A fitter living in BC.0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
