Slant-Fin vs Burnham oil boilers
bee
Member Posts: 1
I need to replace boiler and am looking at these 2 manufacturers. I like the warranty on the Slant Fin but smallest is 121 MBH which seems huge for my under 1600 sq house. The contractor for the Burnham recommended the MPO IQ83 at 74 MBH. I have also heard that the older Burnham V-series had leaks. Isn't the Slant Fin way oversized for me and does that not mean I am wasting oil? Does anyone have an opinion as to which is better or is there something else out there (no I cannot get gas).
Buderus
G115WS/3 , Now just choose your burner , Beckett NX , Carlin EZ-1 , Riello F3 . There you have it . Right around 86 1/2% AFUE . Reliable as you'll get .You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
An Apple and An Orange
The MPO is not a single pass pin-style boiler. It is a 3-pass boiler. That means the flue gases make 3 passes through the iron before they head up your chimney. To you it means less wasted energy up the chimney. I'm assuming since you didn't provide a Slant Fin model # that the boiler your speaking of is a traditional single pass pin-style boiler. Slant Fin does offer boilers similar to the MPO and in the same size range.
The boiler should be sized for the heat loss of the home not based on anything else. The old Burnham V7 which did have issues was a single pass pin-style boiler and totally different iron. You cannot compare the two.There was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
