Is this asbestos?
Joseph_4
Member Posts: 271
I removed an old smith-miller oil fired boiler the other day and am afraid to throw out the bags. The insulation in the jacket was not asbestos rather normal fiberglass type of today's boilers. However. the fire chamber was made of a white fireproof board similar to combustion chamber material of today's boilers and the whole chamber was surrounded by this white fluffy material. It filled about 8 inches wide and six inches high all around the base of the boiler and the cast iron sections sat on top of this base. Does anyone know if this is asbestos.
Joe Hardoon
Joe Hardoon
Without having it analysed
by a laboratory equipped to do that, you can't positively tell one way or the other. It may be cheaper to assume that it is, and deal with it.Br. Jamie, osb
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
