To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
Leak seal
how do you guys feel about those refrigerant leak sealers....do they work/do they harm system?.....thanks Paul S
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
[email protected]
ASMHVACNYC.COM
  • RJRJ Member Posts: 459
    sealers
    Had a bad exp.   used on a low temp Kramer hot gas defrost  R 404 system ,  ended up with restrictions in system
    RJ
  • Paul SPaul S Member Posts: 1,202
    so
    What do you think is the best way to approach trouble jobs with leaks Paul S
    347-692-4777
    [email protected]
    ASMHVACNYC.COM
    leaks
     One way is to press test with nitrogen, check with liquid leak det. solution. Another way is to use a good electronic leak detector while unit still has a refig charge or add nitrogen with a refrig. tracer.   There are dyes you can put into systems, I found they are messy and hard to get out of your guages,
    RJ
  • SpenceSpence Member Posts: 316
    Leak Detection
    Go with RJ; nitro and tracer refrigerant. Only two things belong inside your system, period: refrigerant and oil.
  • unclejohnunclejohn Member Posts: 858
    I tried
    Both Superseal, the one with the one time use hose and the other one that you can reuse a hose that is sold seperatly. Had a lot of trouble with superseal. Could not get it out of the can and stopped using it. So far with the other [sorry I can't remember the brand but in the DC area I've only seen the two ] I have been back to add freon on one. I'm not inclined to use either anymore.
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
