Micro channel coil
Techman
Member Posts: 2,144
The micro channel cond coil is leaking, two passes up from bottom, it is in the middle of the "tubing". Its in a Coleman and the warranty/handling is superb thru Johnstone.
So much for good service
from Johnstone Supply! The in warranty cond coil has still not arrived. Go figure! The customer opted for a new cond unit from MCN Distributors several weeks ago. Will that deterorated cond coil fit where the sun doesn't shine?0 -
wow
Will it fit? Give it a try and let us know - relieve some stress!0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
