Sizing an Internal Expansion vessel???
tangled in wires
Member Posts: 23
in Gas Heating
Tomorrow I'm installing a Bosch ZBR 35 combi boiler for the first time. I'm just reading through the manual and Its says that that Internal Expansion vessel pre-charge pressure must equal the static system height of the boiler.
How exactly do I calculate whether or not I would need to add an on another expansion tank? I believe I need to find out how many gallons the system holds. Now this being a retrofit that might be tricky. Can anyone point me in the right direction here?
If you doing....
a simple system w/ a copper finn tube set up you are prob going to be fine. I might leave a threaded tee on the return to make a way in case you need it.
You can add a bit of air to the extrol inside if you have abnormal height.0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
