Zone
Mpj
Member Posts: 109
I'm looking at boiler replacement job with a total house load of about 75,000 BTU's. I'm thinking about a mod-con with a buffer tank. The house has 6 existing zone and a 80 gallon indirect, the zones are kinda small and only doing a couple rooms each. They have a interior bathroom that has a radiant floor which is about 1,200 BTU's.
How would you guys pipe in this radiant zone? Mixing valve? I series valve? something else?
Is this
bathroom it's own zone with a dedicated thermostat or an individual loop off of a manifold ?You didn't get what you didn't pay for and it will never be what you thought it would .
732-751-1560
Rich McGrath 732-581-38330 -
Zone
Yes, the bathroom is its own zone. It currently have a three way mixing valve off the boiler. It has a t87 thermostat controlling the circulator.0 -
Total houe load
Is that a calculated heat loss? Why so many zones? Might be an opportunity to simplify things...0 -
load
Yes, that is the total house load. He want to keep almost every room on its own zone.0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
