Rinnai boiler
sjm4
Member Posts: 2
in Gas Heating
I am building a new home and planning on installing radiant heat throughout. I have been quoted a Rinnai high efficiency wall-mounted gas boiler by our local supply house. Does anyone have any experience with these boilers?
Aluminum?
Does it have an aluminum exchanger? That would be a negative for m.
Albert Einstein0 -
stainless steel
it has a stainless steel plate heat exchanger0 -
The HX is Stainless.
Rinnai has a few different combis. The 75 & 110 use a plate HX for DHW. The 175c has a 6 gal indirect and the new Q85 & Q130 Premier's have a 24 gal indirect. What were you quoted?0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 879 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
