Silly question
tinnerjohn
Member Posts: 3
in Oil Heating
What is a "tiger loop". I've seen references to them here and in other forums, probably have seen them before or maybe even used / made them, but under a different name. Thanks John
It's a de-aereator
That hooks to to pump with two pipes while needing only a single line to the tank.
http://www.westwoodproducts.com/tigerloop_article.htm explains it pretty well.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
