To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
Beckett AFG Stalls
vegavega Member Posts: 2
Boiler fires right up , but stalls within about one minute. It was turned 10 months ago, even the  electrodes were changed.  But to be on the safe side , I  cleaned boiler, Changed filter, strainer and cad photo cell , Fuel lines were blown clean , fuel is bright pink. It fires up each time but won't remain on
  • SteamheadSteamhead Member Posts: 10,959
    If you had to clean it out after 10 months
    it wasn't set up properly to begin with, You need a pro to fix this, but not the one that was there last time. Try the Find a Contractor page of this site.
  • vegavega Member Posts: 2
    Beckett AFG Stalls
    Actually it didn't need to  be clean , since I was trouble shooting I figured I might as well vacuum it , there was no soot build up .It was the cleanest it's ever been. The nozzle , the strainer and filter were all in very good condition, none of them needed to be changed , I just thought if I was taken it a part I would changed everything that was easy to get too. I didn't want to make 4 trips to the store. Thanks for reading my post and replying to my situation
  • JStarJStar Member Posts: 2,668
    Oil
    What were the combustion numbers?
    - Joe Starosielec
    [email protected]
  • Alan WelchAlan Welch Member Posts: 42
    Stalls ?
    A car stalls. Not an oil burner.  Are you having to push the reset every minute? or is the burner sputtering due to fuel supply issues (underground tank ? )  sounds like you need a good technician to troubleshoot , or we need more info  to help you diagnose.
  • Jim DavisJim Davis Member Posts: 578
    burner shutting down
    If you have a 2-line system the problem is simple, you are losing prime.  If that is a newer burner with the interrupted spark I would expect this to happen.  I don't recommend either one.  Need to go to single line or constant(intermiitent)  spark.
  • Ed N.Y.C.Ed N.Y.C. Member Posts: 68
    stalls
    oil is bright pink ? sounds like h2o in oil.should be red  ED N.Y.C.
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
