To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
peerless ect oil to gas conversion
edgeedge Member Posts: 5
I've got a Peerless ect currently oil fired and would like to convert to gas with a Carlin  EZ if it is possible and legal to do so .Boiler warranty is not a concern ,only whatever paperwork or approvals that I may have to deal with.Any advice would be appreciated
  • JStarJStar Member Posts: 2,668
    Gas
    Did one yesterday. Did a whole lot last year. Go for it. Just be sure to have a tech that does these very often. There is a lot to know and do on these conversions.
    - Joe Starosielec
    [email protected]
  • j aj a Member Posts: 1,358
    converting
    If I were you I would go online and read the manual of the appliance you are thinking about using..As a homeowner pay more attention to information on safety,not so much about the actual install…This will better equip you to ask the correct questions to the installer….As with all gas appliance additions check with gas company and see what size is your service,don’t just look yourself it may be an inserted line….Then check your riser size and meter size….Ask gas company what the pressure is in your area,they will give it to you in in. of water column…There is a lot of homework to do before you do the actual install…Some manufactures require s/s chimney liners….You have already started doing the right thing,,,Get some basic knowledge,and ask the correct questions before you invest your hard earned monies...
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
