To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
condensation
What would cause condensation on the Pvc condensate drain on a air handler...? Thanks Paul S
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
[email protected]
ASMHVACNYC.COM
  • alotlikeearlalotlikeearl Member Posts: 68
    Humidity
    Cold water inside drain and hot humid air on the outside.
  • Paul SPaul S Member Posts: 1,203
    humid
    how do you solve that problem if it didn't happen with the system before?...thanks Paul S
    347-692-4777
    [email protected]
    ASMHVACNYC.COM
  • RJRJ Member Posts: 459
    condensation
    Any time you are operating a DX or chillwater coil you will have some condensate if the unit is operating correctly and there is moisture present in the air stream,  the higher the relative humidity the more condensate.  check your cond. drain line and trap and flush them out if needed, make sure your trap and condensate piping are installed per unit recommendations.
    RJ
    Insulate
    Insulate the drain line with Armaflex as you would a suction line.
    condensation
    Thanks guys....Paul S
    347-692-4777
    [email protected]
    ASMHVACNYC.COM
  • Eugene SilbersteinEugene Silberstein Member Posts: 349
    Best Practice
    It is best practice to insulate the condensate drain line for a minimum of ten feet to help eliminate the condensation issues.
    Eugene
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
