New Vitodens 200 Specs Online now:
SpeyFitter
Member Posts: 422
The new Vitodens 200 BH2A - Have a look: <a href="http://www.viessmann.ca/en/Residential/Products/gas/Vitodens_200_B2HA.html">http://www.viessmann.ca/en/Residential/Products/gas/Vitodens_200_B2HA.html</a>
Extended modulation range
Did you guys notice the increased range of the Lambda Pro combustion numbers. They now have a lower and higher range with oxygen percentages (down to 3.8% from 4.4% and up to 7.3% from 6.9% oxygen) (and corresponding increased/decreased CO2), probably to accomodate the higher modulation ranges offered. Also, Viessmann has a 6.75 to 1 modulation range on the 19,000 to 125,000 BTUH. I guess manufacturers are pushing the limits now a days and the old days of 5 to 1 are gone perhaps? Are the certification agencies bending the rules or was the numbers changed?There was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
