re..circ
Paul S_3
Member Posts: 1,261
I'm doing a job which involves a domestic hw re-circulating pump...I bought the pump from my local plumbing supply house that I purchase most of my equipment from...is a bronze body pump with the aquastar built in...it has a temperature adjustment on the motor...I just want to double check the way I piped it in...the customer (general contractor) ran the hot water lines and return line...its piped hot water out of the indirect...to all the fixtures then back to pump them into bottom of indirect/cold water in....there is a tee there...I would usually look it up in the installation manual but its misplaced and its Sunday...thanks Paul S
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
347-692-4777
ASMHVACNYC.COM
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
