Never saw this LWCO before
Robert O'Brien
Member Posts: 3,540
34 years and this is a first!
cool, i cant read the label plate.
any chance you can post what it says.gwgillplumbingandheating.com
LWCO
Very cool, does it work?0 -
Drain
Is there a way to drain that thing?0 -
Homart (Sears) 651
Homart boiler,I'd guess late 50's-early 60'sTo learn more about this professional, click here to visit their ad in Find A Contractor.0 -
PART NUMBER: 651.9228
If I looked it up right, the part number is 651.9228, but they say it's no longer available.Just another DIYer | King of Prussia, PA
Sears boilers
were supplied by Delco some decades ago, more recently Dunkirk. I think I see where they say who made that LWCO, but can't make it out.
What are you going to replace it with?All Steamed Up, Inc.
Consulting0 -
Steamhead
If I told you,I'd ruin your holiday. Hint,there are 2 HW zones off the boilerTo learn more about this professional, click here to visit their ad in Find A Contractor.0 -
Hot water?0 -
I did not look it up, but I blew up the picture.
It has a HOMART logo on top.
Then a line of small blurry text.
then
LOW WATER CUTOFF
easily read,
then a hole that might be for a set-screw
then
Model ?K 01 [3 or 8] 51
12 LBS MAX PRESS
110 V 4.6 AMP 1/4 HP
SEARS ROEBUCK AND CO
MFD BY blurry CONTROLS U.S.A.
blurry might be LE??A??0 -
Homart History
Homart was a brand name owned by Sears and used to market heating equipment manufactured by Dornback Furnace and Foundry of Garfield Heights, Ohio from the mid-40s to 1968. Sears let the trademark expire in 1992, and Dornback was acquired by Adams Manufacturing that same year. They are still in business but today only make hot-air furnaces which they sell under their own name.
Of course, this is probably all academic since it's unlikely that Dornback manufactured the controls or even chose which controls and trim Sears packaged with their boilers.Just another DIYer | King of Prussia, PA
wow nice dirt leg on that water heater
I see you got shoddy workers there too. Of course the boiler was from sears I should not expect miracles.Cost is what you spend , value is what you get.
cell # 413-841-6726
Homart
The house I grew up in which my parents sold in 2006 had a Homart 1/2HP sump pump from 1958. Was one of the best pumps I have ever seen and many pumps came and gone while that one just sat there working (we had 3 in the house). It was sold with the house.
Never knew they made other things. I guess its kind of like the Kenmore name is now?Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
Sears
we always refered to them as homfart. Heil made furnaces for them years back, as well as Delco, as Charlie said. Far from top of the line products. LWCO Looks like an ITT made it for Homart?0 -
Sears Catalog
One very nice thing about the Homart line of furnaces and boilers, etc., is that they were pictured in the Sears catalog. Not only did they describe the product very well, but they also showed diagrams of hot it could be installed. Looking back, I now find it more than just a little bit humerus that I, as a 5th grader, figured out how we could install a hot-water baseboard system in our house. Of course, we didn't to it.
Several years later, when I was a senior in high school, I did install a new gas furnace with a much needed split system central AC, which allowed us to stop using the old swamp cooler. My dad was fully prepared to call the service department at Sears and have them finish the job, but he was pleasantly surprised when the system worked just fine.
Sears Homart may have been less than top of the line quality, but they put reasonable priced products and installation information within the reach of the average everyday person.Dave in Quad Cities, America
http://grandviewdavenport.com0 -
During the summer
of '56, my dad and I installed a Sears hot water heating system in his house. Built in '50, it had a coal fired gravity hot air heating plant. Sears furnished the whole kit; the boiler, baseboard radiators, copper tube and fittings, controls, black pipe, pipe vice, threading dies. Even lard oil for threading the pipe. Had to change a few seals in the circulating pump over the years, but it wasn't until his later years that my dad had others maintain it. The circulating pump got changed out to a B&G in the mid 80's, and the boiler in the mid 90's. Actually, there was really nothing wrong with the boiler, but due to its age, my dad thought it would be prudent to change it out.Dennis Pataki. Former Service Manager and Heating Pump Product Manager for Nash Engineering Company. Phone: 1-888 853 9963
The first step in solving any problem is TO IDENTIFY THE PROBLEM.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
