r22 drop in
Paul_69
Member Posts: 251
could the professor enlighten us about m099 etc. for retro fit. i am very leary about using any of them right now. i would rather the customer fix leaks or convert to 410a. if just a small amt. of r22 to top off a system , i would rather chge them a little more money than take risks. help!!
Mo99
It is more important to fix the leaks when converting to the drop in refrigerants. Like 410a, they leak their blend at different rates and will loose their efectiveness. Just converted my wife's parents unit to mo99 due to the cost difference. Fixed the leaks and changed out the dryers and shrader cores. At that time r22 cost over $500 a jug while I could get the mo99 for about $150 per jug.If the women don't find you handsome, they should at least find you handy!0 -
Mo99
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
