Hot Water Boiler Extrol and Fill Valve
Old_Navy_BT
Member Posts: 2
Hi,
Could someone tell me if the pressure setting of the fill valve (Watts SB1156F) and the charge pressure of the Extrol tank should be the same or how should it be set up. The valve came preset to 15 psi and the tank (size 60) is precharged to 12.
The house is a two story cape with only one zone.
Thanks,
Dan
Thanks,
Dan
Both should be the same
And set to the design pressure of the system. 15# is about right for a two story house -- unless the distance from the low point of the system to the high point is over 23 feet.
Design pressure (minimum) = distance between those points times 0.434 plus 5 pounds.0 -
Thanks,
No more dripping relief valve.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 879 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
