To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
unloader
can someone explain how an unloader works, and its importance in regulating oil flow.
learned there was too much oil in a compressor
thanks
  • RJRJ Member Posts: 459
    unloader
    Unloaders dont regulate oil they are a capacity control   look up suction cut off unloader or   www.xpedio.carrier/idc/groups/public/documents/...     sounds like you have an oil return problem which someone misdiagnosed, so they kept adding more oil.   at this point i would recommend that you take a class on compressors at your carrier dealer and recheck the design of your system  (piping sizes, unit sizing and air side design
    RJ
  • unclejohnunclejohn Member Posts: 858
    On old
    5f Carrier compressors they used oil pressure to load and unload the heads. On the O6's they used refrig. pressure to overcome spring pressure and would load and unload that way. A loaded head would work like a normal recip. a unloaded head would by pass the gas back into the crankcase through a check valve in the valve plate or a bypass internal in  the head or external back into the crankcase.
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
