Good vacuum pump for hobby?
ChrisJ
Member Posts: 15,588
As some already know refrigeration is a hobby of mine so I don't do it much. I'm in need of a good vacuum pump for occasional use and am curious if anyone could recommend one? I looked at a few made by CPS but don't know where they rank in the scheme of things.
Also is a digital vacrometer really needed or is the one on most manifold sets good enough? I have a set of Yellowjacket II brute gauges as well as a CPS R134A set.
My main projects will be refrigerators which have refrigerants that are very sensitive to moisture so a good vacuum is important. I have all the time in the world when doing this so speed isn't an issue but I want a good strong vacuum.
Thank you for your time and as always all comments are welcome.
Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment
Got one
Decided to go with a Robinair 15600.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
