CONVERT TO GAS FIRED BOILER IN BALTIMORE
Tom Elam
Member Posts: 57
Greetings,
I am looking at a 1068ft2 row house on Chesterfield Ave in Baltimore to purchase for a rental property. I plan on holding the property long term. There is a <strong>very</strong> old oil fired steam heating system boiler and a newer gas fired water heater. I want to get rid of the oil and use natural gas for the fuel source. I work in a power plant with boilers but know nothing about steam heating for residential use. There is a head tank in a second floor closet and the sight glass is half full. I assume this means the boiler doesn't leak. I realize that I will have to get a tech to look at it to see if a gas burner can be retrofitted to it.
I am looking for reasons to keep it or replace the boiler:
1,The first is safety, after testing/replacing all the safety devices would you be comfortable with it in your basement?
2.Fuel efficiency of an old boiler against a new boiler. I want the tenant to have money left to pay me after they pay the gas and electric bill.
3.Maintenance nightmares for my property manager when the tenant calls at 2 am with no heat.
4.Maintenance costs associated with upgrading the burner and controls and keeping old equipment running verses installing a new boiler.
Thank you for your input,
Tom
Tom
Boiler
If there is an expansion tank with a sight glass, then you have an old gravity hot water system, not steam.
The best thing you can do is call Steamhead. He works out of the Blatimore are.
http://www.heatinghelp.com/professional/79/All-Steamed-Up-Inc0 -
Contact Steamhead
Hi- I agree with JStar, in the Baltimore area for a expert on these old systems, Frank "Steamhead" Wilsey, Phone: 410-321-8116, is the person you want to contact. He's listed in the "Find a Contractor" section of this website. He does a lot of oil to gas conversions and boiler installations
- Rod
Edit: Sorry about that- Phone number corrected.0 -
Thanks, all
Tom, that number is 410-321-8116. We'll be in the office later this afternoon, leave a message if we're not there and we'll get right back to you.All Steamed Up, Inc.
Consulting0 -
Steamhead
No question about it. Go with steamhead. You are one lucky man!0 -
Steam
I would tend to agree with Jstar that you probably an old gravity hot water system. One of the most intriguing systems out there. I have a customer who told me that when they first moved into their house, two plumbers spent a full 90 minutes arguing about whether the system was steam or hot water. Turns out it was a gravity system. Not many people understand gravity systems very well so do yourself a very big favor and hire steamhead.0 -
thanks for your help
Frank,
I will give you a call for an estimate if the oner and I can make a deal.
Tom0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
