Old style toilet flush valves
Timco
Member Posts: 3,040
Installed a Standard Moderno 1927 toilet in my basement. Used a new spud and flush valve / plunger.
It constantly allows the tank to drain. It's not the threaded connection to the overflow tube.
Does it need more water in the tank to hold the plunger down tighter? I don't want to use pool & spa lube with new parts. I've only got the tank filling half way or a bit more.
Happy fathers day!
Tim
Happy fathers day!
Tim
Either
the flush valve seat is misshapen, or the flush ball (plunger) is a bad fit. Or you might have the guide arm out of alignment- it should be centered over the seat.
Some of those brass flush valves had cup-shaped seats. If yours does, a non-rounded flush ball won't work well. Try using one that's made for the Eljer tank with china seat.
I've never seen a Moderno, though the Modernus that came out in the 1930s was quite popular. Can you post a pic?All Steamed Up, Inc.
Consulting0 -
Double check
Double check that one-inch diameter refill tube. I've seen them corrode and leak above the threads.
More commonly, it's the tank ball not fitting the flush valve properly.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Pics
I'll take pics later. Great toilet. Long days. I covered all the basics but did not consider the plunger shape. The flush valve is new so no corrosion possibility.
Thanks for the advise!
TimJust a guy running some pipes.0 -
Toilet problem
Could the toilet be siphoning? The fill tube should be cut and clipped to overflow.
Rob
Agreed
that after-fill tube is probably siphoning.
Crane had a similar design that hid the flush ell, I think they called it the Neu-Way. Is the inside-bowl design of yours the same as the Ejecto or the Modernus?All Steamed Up, Inc.
Consulting0 -
Good call, Rob
I think you nailed it on that refill supply hose shoved down the refill tube.
Timco?8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Siphon!!
Yes. Ashamed to admit, that's what we had!! Not a single recharge since I snipped the tube. The funniest thing is I went down there and heard it drip. I figured it had recharged and was just letting a few drops out. Then I pulled that tube out from the overflow tube and looked in there but could not see any signs of leaking at all. With the tube out, no leaking. Then stuck tube back in and hour later, recharge.
Thanks! Heard the email because I am subscribed. This toe thing and a bruised heel opposite foot has made me hopelessly behind.
I don't shop on Sundays so a brick or 3 tomorrow!! We really appreciate the advise. Love that toilet. I've had it for years. I'll take an inside pic later. No idea what the others look like. We love the Deco look of this. Classic!
Syphonage:
If you buy a Fluidmaster #400 Pro or equal, they come with a clip that keeps the overflow tube below the after drip tube. With a tank that has a Syphonage protected ballcock, it will syphon if the tank is full and the water is overflowing. That's what that clip/device is for.0 -
Overflows:
The overflow is too high. It needs to be cut down. That fluidmaster ballcock that you installed isn't using the clip to keep the overflow tube above the flood level rim of the overflow tube.
That guide arm may not be perfect for the bulb stem. They have adjustable ones. It may keep the flush bulb cocked and off center0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
