To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
new hotwater system
wildmangreenwildmangreen Member Posts: 2
got a charmaster indoor woodfired water boiler and storage tank plus a water to water heat exchanger coming soon...
want to know about hooking this system up to a series of pex radiant heat tubes and a few cast iron radiators...
can anyone tell me what sort of plumbing etc. is involved here?
  • Paul PolletsPaul Pollets Member Posts: 2,993
    Shopping
    There's a lot of info required to make the hookups, not to mention technical skill and expertise. You'd do best to find a local pro who knows how to assemble the mechanicals without creating numerous safety hazards.
  • wildmangreenwildmangreen Member Posts: 2
    thanks
    that was really helpful.
  • Jamie HallJamie Hall Member Posts: 6,054
    I am quite sure,
    knowing Paul, that he meant no disrespect.  However, unfortunately, he's right.  Without knowing -- quite exactly -- what the heat losses in the spaces to be heated are, how much radiant tubing is involved and how it is arranged, how big the radiators are and where they are located (for example: are they all in the same space?), what the heat output of the boiler is, how tall the building is -- and a host of other factors! -- it would be impossible for anyone to answer your question.
    One could start off by simply saying something about at least two pumps, several controls, several powered valves, probably two expansion tanks, etc. etc. -- but that isn't much help either, is it?
    Jamie
    Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England.
    Hoffman Equipped System (all original except boiler), Weil-McClain 580, 2.75 gph Carlin, Vapourstat 0.5 -- 6.0 ounces per square inch
  • SWEISWEI Member Posts: 7,356
    Assuming you want to pipe it yourself
    I'd still consider hiring an experienced designer.
    You could start by reading this http://www.caleffi.us/en_US/caleffi/Details/Magazines/pdf/idronics_10_us.pdf
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
