summer/winter hookup & oil furnace running when no water is being used
amblergirl
Member Posts: 1
Hi, we have a summer/winter hookup for our 1920 foursquare (oil furnace . . . old cast iron radiators, etc.) I understand the basics of the system, but one thing puzzles me. In the summer (now) when NO HOT WATER is being called for anywhere in the house (washer/dishwasher/showers/sinks not being used), the furnace occasionally kicks in. Is this supposed to happen? I hate to burn oil without a need for it.
A picture..
A picture would help. It sounds like you have an indirect coil and your boiler is designed to be always hot."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Need more info
Even if nothing is being used, the coil or tank may have lost enough temperature to make the aquastat call in the boiler...
Is this an internal tankless or an indirect... Model and age, or like Zmann said a pic would be great..0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
