solar heater control
P38ace
Member Posts: 1
I have a Robertshaw Solar Commander ser#385F Sensor Wiring Class 2.
It won't shutoff when the sun sets. I would like to replace it. Where could I go to find a replacement? I believe it is a differential temperature type. It controls the circulation pumps on an indirect heat exchanger.
Sounds like...
You are looking for something like this?
http://tekmarcontrols.com/products/alternative-energy/155.html
You are trying to turn on a circulator when the difference between 2 sensors reaches a certain temperature?
Post a drawing or picture if you need help confirming compatibility.
Albert Einstein0 -
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
