Peerless burner plate insulation
Wallman
Member Posts: 1
The interior line on the plate seems detached, I manually pushed it back to the plate inner surface, but the plate, after a while, decolored and shows the burning sign, rust-like.
Could you please tell me as to what kind of material to use and how to reline the oil burner plate?
Thanks.
Thanks.
That's usually called the "front refractory"
Any contractor should be able to get it from Peerless. What model boiler?All Steamed Up, Inc.
Consulting0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
