Piping question for Quietside boiler / tankless install..
Timco
Member Posts: 3,040
So I am installing a Quietside 120 in my own home. One of my two 40 gal went down and I just did not have the heart to simply plop another tank in there. I need space and want the high-efficiency as well.
My house is about 1700 sq', maybe 80k heatloss and I added some rads in the unfinished basement so including that maybe 100k. I have a front & back zone.
With 3/4" taps from the boiler, since I am zoning and may wish to add a zone some day, wouldn't a 2" manifold / buffer tube under the boiler with a primary pump be the best way to keep flow up? Then maybe 1" manifold off that for supply & return and mix in the buffer?
Thanks, Tim
Thanks, Tim
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
