To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
Air Lock
PcastanonPcastanon Member Posts: 2
Hello,
I am helping my father out with his oil burner. He ran out of oil, I noticed a large amount of sludge in line blew out line, switched filters and nozzles and cleaned pump screen. Motor has play all looks well. I tired purging the line and I am bone dry. I cannot get any oil to pull through? Is it the pump that needs to be replaced or should I use a suction pump to get the oil up to burner then reconnect?
  • STEVEusaPASTEVEusaPA Member Posts: 1,259
    Could be a number of things....
    Was it working before you started working on it? If so...
    1. Check for proper installation of pump gasket, if its a Suntec there's a right and wrong way to put it on.
    2. Check gasket & seal of oil filter.  If the gasket isn't installed and sealed tight, it will suck air all day.  Open it back up.  I usually wipe a little heating oil around both sides of gasket.
    1 & 2 are pretty important, but even more important if its a lift job vs. a gravity job.
    Then you're going to need to power purge it.
    If that doesn't work, let us know, although at this point you're going to need a pro..
    steve
  • PcastanonPcastanon Member Posts: 2
    air lock
    Thanks Steve, I had double checked all gaskets, I checked the oil line for any pin holes, I didn't find anything unusual. I decided to change the pump to a newer one with the notion that all the sludge that passed though the system must have clogged it. As soon as I replaced we struck black gold. All is working well now. Thanks for the help.
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
