To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
radiant heating/cooling combi systems???
I've been trying to learn more about radiant cooling systems ( a pretty new concept here). I do a lot of radiant heating, was thinking about a super simple way to integrate radiant cooling. Maybe running a coil through the incoming cold water supply for domestic hot water? Anything to get rid of (or at least minimise)  those bloody ducts that are always in the way of my beautiful pipes. Keep in mind that I live in a climate (and city) where a/c is hardly a necessity and is only something I dream of about 4 days a year. Most houses have no existing cooling or ventilation- I thought it could be interesting in retrofits to add ventilation, but make it much smaller so that it only accommodates the necessary changes for health and to leave the cooling to the radiant system (even if it only lowers the T by 1 or 2 degrees C, that's still better than nothing for most people, when added to common-sense passive cooling). Also interested in learning more about combined systems in general for new construction or major renos.  Any ideas, thoughts or links to places I could learn more? Thanks
  • RichRich Member Posts: 2,129
    Radiant heat/cool combi
    Healthyheating.com .  You will be able to research this there . John Siegenthaler just did a webinar this afternoon hosted by Caleffi that was really informative also , should be archived within a few days .
    You didn't get what you didn't pay for and it will never be what you thought it would .
    Langans Plumbing & Heating LLC 732-751-1560
    Serving most of New Jersey , Eastern Pa .
    Consultation , Design & Installation
    Rich McGrath 732-581-3833
  • GermanPlumberGermanPlumber Member Posts: 44
    Robur
    We do it in Europe . I work with Gas Absorbtion Heat Pumps from Robur . The AR unit will Heat and Cool. You can check it out here www.robur.com
    Greetings to the US,
    Mario
  • ChrisChris Member Posts: 3,040
    "The bitter taste of a poor installation remains much longer than the sweet taste of the lowest price."
  • Jean-David BeyerJean-David Beyer Member Posts: 2,510
    http://www.uponor-usa.com/Misc/RCDM/Default.aspx
    The page requested could not be found.
    That's Weird
    It opens for me. Maybe becuase I copied and pasted from my IPad. It can be found at
    www.uponorpro.com
    They recently release a Radiant Cooling Complete Design Manual. Actually working on a radiant heating and cooling project right now. Pretty amazing how much cooling you can get out of a floor. About 11 Btuhr sqft in this project.
    That link works.
    Chris
    Chris
    June 9, 2013
    @ 8:49 AM
    Contact this user
    That's Weird
    www.uponorpro.com
  • SWEISWEI Member Posts: 7,356
    11 BTU/hr/ft2
    is enough to reduce the size of an air conditioning system (and more importantly, the accompanying ductwork) by a LOT.
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
