Old Boiler Question
BrianScott
Member Posts: 1
I came across an old boiler I thought I might be able to use to heat my house. I am building a 2500 sq. ft. house and will have radiant heat in the entire basement and first floor. I have a geo system designed but have access to a lot of wood and wanted to get an old boiler like this one to put outside under a roof of some sort where I can chop wood and load it up in winter. To me (no experience with boilers) this looks like a old tank that was built to last and probably would work great. My question for you (veteran plumber with experience) is would I be making a mistake here? Are these things prone to rotting out or something else? Also can anyone tell me more about this unit, I could find very little info when I searched online.
Thanks,
Brian
Thanks,
Brian
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
