To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
Vertical Seperation limitations.
My Rheem/Rudd books show a vertical heigh limitation as being 25' for most of their split cond units. What is it on the units that you put in? I see LOTS of "rule breakers" out there. What do you do for a "proper charging" then?
  • SpenceSpence Member Posts: 316
    Line Rise or Drop
    Even though R/R has stated a limit, I would still call them. Those guidelines are for the rule breakers you mentioned to try to keep them out of trouble. R/R may say 25 is 25, or they will help you engineer a way, such as tubing sizes, perhaps a suction line trap, sump heater, hard start kit, or other approved methods. Again, their proprietary software will really help you save time and lower your blood pressure if you run into these situations often.
  • TechmanTechman Member Posts: 2,141
    Vertical
    My goofy mistake, I wasn't reading the charts correctly. Vert Sep can be up to 56'.  Thanks , John @MCN  for helping.
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
