To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
under ground tank
Paul SPaul S Member Posts: 1,202
Underground tank with clogged line....they used to have two pipe system....return line is plugged probably due to partially clogged line....now the supply line is completely clogged 25" of vacuum.. Lines run in ground in a finished basement....I know I shouldn't blow back back because of possible foot valve at tank....system is running temporarily with a fiver gallon oil tank with oil line in it....one option is install brand new tank in basement....question is does anyone have any advice on how to unclog thus oil line without digging up old tank or installing new one in basement....feel bad for customer old lady no money.... Thank you Paul S
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
  • billtwocasebilltwocase Member Posts: 2,385
    plugged line
    Paul, do you have a push/pull pump? Did you try to blow back to the tank already?  Not all installed foot  valves, so you may just need to blow the line. If it does blow back, I would back flush it with STR-2, or some additive to help clear the line. You can also run a line down the fill, if it is a straight shot, by making a T-Y, or dig up the lines
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
