Dear Professor.
Techman
Member Posts: 2,144
Could you kindly take us an actual (KindaSorta) pressure trip thru a typical(res) AC system.Lets say R22 , 4T ,13SEER,TXV,82 1/2* ambient, you pick the RH%, proper LL/SL size, for me (please) a FD/SGMI, Unit running, indoor conditions are "stableized", oh yea, out of the cond unit 6.25' horizintal, 20-24' up & 35' horizontial & 6' up & down for that antisyphon loop thing, LL is insulated in attic except maybe 5'( as per Spence),into&outto the TXV ,thru the coil, and other stuff back to our starting point !?!?!??? I know you could if you wanted to ,thats why I called you DEAR !
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
