Lay out
Sparkydsh
Member Posts: 1
I'm finishing the second floor on my house, 500 sq feet. Do I need to lay out the radiators under the windows? Or can they be located on interior walls? The exterior walls will be very tricky to install. Boiler heat.
more important than placement is
balance and sizing, heat loss calcs for each room and then degradation calcs for the heat loss to make up for the energy loss as the water moves down the loop.... Other than that just throw it up wherever you can, I always tell my customers, I'm not a magician, I can put the emitter / element where ever they want but the more invasive and time consuming the more it costs, plus when you start to need to build soffits and block in tubing that goes up walls customers would much rather have it where ever it is easiest.. I find baseboard is much less tricky than duct work and radiant panels... Truth of the matter is outside walls are usually the easiest place to add the board and make it a continuous loop not to mention fit the amount needed... Inside walls are much tougher normally...0 -
Your body radiates heat
to cold surfaces. The window having the lowest r value will be the coldest surface in the room. If you dont install the radiators under the windows to provide a warm air curtain, you will be more likely to feel the effects of cold 70.
Remember, the more radiation you add, the lower the temperature water you can use but you must add it equally in each room.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
