Chemical for Cleaning Blocked Boiler heat exchangers?
SpeyFitter
Member Posts: 422
in Gas Heating
Are there any products/chemicals you use that "assist" your manual efforts in the cleaning of blocked cast iron boiler heat exchangers?
Class 'A' Gas Fitter - Certified Hydronic Systems Designer - Journeyman Plumber
My fave product
Are you talking on the water or combustion side? The product I use to clean cast iron heat exchangers is a dolly to haul it outside and on to a truck to the scrap yard. ; )0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
