Leaky steam supply valve
ben_18
Member Posts: 70
I have the recessed cast-iron convector shown on pg. 104 in "We got steam heat." The supply valve is leaking from the big nut on the union. The area under the radiator is very tight. I tried using a channel lock plier to loosen the nut but it wouldn't budge. Any suggestion on the type of wrench to use?
Burnham Independence IN8
Try to avoid
anything with teeth on it! They'll mess up the nut. A good channel lock, though, should do it OK.
However, watch out for union nuts. The old "righty tighty lefty loosey" doesn't always apply the way you think it's going to. If trying to turn it one way doesn't work, try the other -- sounds obvious, perhaps, and if you've already done that, sorry... but as I say, it's not always obvious which way tightens on a union when you're just looking at it.Br. Jamie, osb
Still unable to
loosen the big nut on the union using a channel lock. Any other ideas?
Here's a picture of it.Burnham Independence IN80 -
Loosening the union nut
Try to find a big open end wrench of the appropriate size at harbor freight, so you have a good grip on the nut. Use a few light hammer taps in both directions to see if it moves.
Loosening it slightly will enable you to retighten it.
If it still leaks, then taking the joint apart completely will allow you to wipe the faces clean, and put a little Dawn liquid on them to lubricate them enough to align themselves for a good seal, as you tighten up the nut.--NBC0 -
I have found
that a few hammer blows on the union nut itself will allow it to be freed up using a wrench. It's best to back-up the nut on the opposite side with a heavy piece of metal, like the heel of a pipe wrench. Don't get carried away with the hammer blows. This method is also used to break up a cast iron fitting if it can't be loosened up with a wrench.Dennis Pataki. Former Service Manager and Heating Pump Product Manager for Nash Engineering Company. Phone: 1-888 853 9963
The first step in solving any problem is TO IDENTIFY THE PROBLEM.0 -
Open ended wrench
Thanks!
What do you mean by open ended wrench. Is it an adjustable wrench. I don't one big enough for the nut will fit in there. Can you give me a URL of the wrench?
And do you mean regular dawn dish washing detergent?Burnham Independence IN80
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
