WarmRite Ipex Control Board
Plumdog_2
Member Posts: 873
I'm needing the controller for one of these panels, it looks like a Tekmar mixing control or snowmelt control (356 or 656?) except rebadged. I believe it is Pulse Width Modulation for the injection pump rather than variable speed. Has OD sensor and supply sensor, powers a System circ and injection mix circ, and demands heat from a Buderus C.I. boiler on a primary loop. Should I just switch to a 356? The injection pump is a Grundfos 15-52.
Never Mind...
It was a 356 of sorts. I put in a new one and all is well. There will be a special place reserved in the low-rent section of @ell for those guys at Kitec. Would it be too much expense to give maybe 3-4 inches of slack in the wire lengths so an old guy doesn't have to spend two hours on his hands and knees in a filthy crawlspace trying to stretch those dinky wires? Good ridance. Gimme back the money I spent on Special Tools, too.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 72 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 878 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
