wet air vents
ben_18
ben_18 Member Posts: 70
When I took the air vent off the radiator it was wet inside. Does this mean the radiator isn't pitched right?
Burnham Independence IN8
    Jamie Hall Member Posts: 23,275
    Do you mean wet
    as in drops of water, or wet as in puddles on the floor?  If the former, no problem -- it doesn't close until steam hits it, so it's going to have some condensate in it.  If the latter, it probably isn't a pitch problem; if it's a problem at all, it may be that the vent is a bit too fast.
  • ben_18
    Its just some
    moisture. I guess it's not a problem. Thanks.
    Any tips on preparing the boiler for the downtime during the summer?
