Cat 1 vs Cat 3 - benefits to Cat 3?
SpeyFitter
Member Posts: 422
in Gas Heating
Cat 1 appliances are mid efficient non positive vent pressure - non condensing. Cat 3 are mid efficient positive vent pressure, non condensing. If an appliance can run either option (e.g Viessmann Vitorond 200), what benefits are there to running a cat 3 over a cat 1? The only one I now know of is you can run smaller vent sizes on Cat 3 obviously because the positive vent pressure helps push the flue gas out instead of relying on draft to move it. The cat 3 may be slightly safter as it has to be a fully sealed vent where as a Cat 1 in a lot of cases requires some form of draft control (e.g. draft hood, barometric damper) which could spill in some situations. Any other benefits to Cat 3?
Class 'A' Gas Fitter - Certified Hydronic Systems Designer - Journeyman Plumber
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
