oil lines & co2 cartridges
dana p._2
Member Posts: 8
is it in the mass code book about NOTusing co2 cartridges to blow out oil lines
Not sure if it says not to specifically I will need to check
BUT I was always told to not do it as popping a line, joint or seal could be a big cleanup nightmare. If the line is that clogged that your push pull won't clear it maybe you need to fix the cause and start with new pipe?Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating0
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
