QUESTION FOR THE MONTH
All welcome to try except Eugene.
Scenario, two houses side by side, both have been with out power for 2 days.Outdoor temperature 115F 90%rh. Inside temperature 98F 90%fh. Both house lost a compressor, both three ton scroll, house- a runs on r-22 house- b runs on 410a. Both systems use a fixed orFice on the indoor coil. Service company A arriVeS at house-a at 10:00 am to replace compressors. Service company B arrives 5 minutes later to house B to replace compressor. Service company A finishes, collects and leaves at 2:30 p.m. Service Company B finishes, collects and leaves at 9:30 pm. why so long.
PEACE NE WITH YOU
DAVID C. BROOME
PEACE NE WITH YOU
DAVID C. BROOME
Compressors
I bet the company working on the system with R410A had a heck of a time charging their unit. Maybe they installed a second compressor as well?0 -
A/C
House "A" had a service contract and paid a flat fee. House "B" called someone from the yellow pages, and paid time and materials?0 -
Oh c'mon
no AC talk yet, its still 30 at night over here... 410a doesn't like high ambients, but recovering, then holding, then flushing the system, and changing the txv, compressor, ect , then nitrogen testing, then vacc-ing it down, then charging it, it takes a lot of time... I have done my share, none of them are fun, although we dont normally get 115* ambients around here... maybe 98* but not very often... I can count on one hand how many triple digit days we have had in my memory..0 -
Freon
Moisture. It's harder to pull moisture out of a 410a system. If left open to long it is harder to get down to an acceptable micron reading.
James0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 886 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
