To get email notification when someone adds to a thread you're following, click on the star in the thread's header and it will turn yellow; click again to turn it off. To edit your profile, click on the gear.
The Wall has a powerful search engine that will go all the way back to 2002. Use "quotation marks" around multiple-word searches. RIGHT-CLICK on the results and choose Open Link In New Window so you'll be able to get back to your results. Happy searching!
In fairness to all, we don't discuss pricing on the Wall. Thanks for your cooperation.
dry charged condensor changeout
When you can not find a new  R410 coil to fit above a oil furnace and existing coil has a orifice control .Can that be used? thank you for any input
  • SpenceSpence Member Posts: 316
    R-22 Dry Units
    You are putting yourself and the equipment in a tough situation with any type of fixed metering device. Quality-driven makers of the dry units assume you will be using a TXV. You have possibilities from the easy to the extreme: (1) Locate an R-22 coil that will "match" the unit you propose; (2) Remove the orifice and pipe in a TXV; (3) Check other makers to see if they have an "N" coil that may be less tall; (4) Determine if the furnace is approved for horizontal application and change the configuration, or; (5) Replace the furnace, giving your customer higher efficiency, the advantage of R-410A, and the long life expectancy that comes with AHRI certified combinations.
  • John MillsJohn Mills Member Posts: 745
    short coils
    Some ADP and Aspen coils are pretty short and AHRI rate with a new 410 13 SEER machine. Often TXV is required. But sure beats the compromised SEER and capacity of putting a dry 13 SEER on some old coil.
  • SparrowSparrow Member Posts: 4
    m-coil
    Allstyle coil out of houston tx has m-coils that are 15.5" high. i've been selling them for a couple of years now in ct. and have had no problems. you have to buy a seperate txv for either 410a or r22.
    Short Coils
    This is great news; thanks!
Welcome
It looks like you're new here. If you want to get involved, click one of these buttons!
