Taco 5000 O- Rings
oldpipefitter
Member Posts: 9
Have 3 Taco 5000's (1/2") 3- way valves leaking out from under the adjustment knob. Found the replacement instructions on Taco's site but no where can i find the part number for the parts kit. Can anybody help with this. I just want to make sure i get the right kits when I order them from my local supply house. Thanks!
Tough call
5001-001rp is the number on the element kits I stock on my trucks, but the problem is that costs me almost as much as a new valve , so I normally change out the valve, its faster, easier, and guaranteed to work, vs pulling apart a corroded old valve, and reusing the body...
Good luck, another option is to call Taco, and see if they will send you a seal kit, they are really easy to work with...0
- 85.6K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
