side arm heat-x advantages and disadvantages
andrew123
Member Posts: 8
are there any disadvantages to installing a side arm heat exchanger on an existing electric water heater,to be connected from the primary loop of a cgi ng boiler currently feeding 2 air handlers.
Do you mean
Have a plate exchanger pre-heat the water before it goes into the water heater?
Then .... No down side that I can see...
You likely wouldn't even need the elec. heater to be on if it were piped right...
:-) Ken0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
