Paul S.
haventseenenough
Member Posts: 61
Morning, does anybody know where I can get a online version of a manual J & D
calculators. This may be asking alot but free?
Manual J
Do you have a blueprint? I can do the calculations for you. If you are interested in the calculation process yourself, you can try the One-time version of HVAC Calc.0 -
Reply
Joe, this is a design and build retrofit on new construction.
The owner went with a LG 36000 btu multi condenser split system
With two mini air handlers. He did not want to use the factory direct wall mount
unit. They want to have every thing done contrary to manufacturer specs.
That is way I would like to get the manual D.
Paul0
- 85.7K THE MAIN WALL
- 51 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 850 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.5K Strictly Steam
- 51 Water Quality
- 38 Industry Classes
- 55 Job Opportunities
