Question on sizing flat plate heat exchangers
earl burnermann
Member Posts: 126
So I am designing a system for my home as a project for the system design class I am attending. My home is heated by a oil fired hot water boiler and baseboard. I could just design the ac side for this class but I’m thinking of also including a hot water coil which would eliminate the baseboard. I completed the Manual J for my home and it states that my heat loss is 65,400 Btu/hr.
My plan is to use a flat plate heat exchanger, the type of heat exchanger that the system 2000 uses to make domestic hot water using a plain electric water storage tank, to supply a 50/50 premix of glycol to the coil. My problem is that I am having trouble finding the Btu ratings of these devices. Also, the specific heat of glycol is .85. So I figure the flat coil would have to be rated at 75,000 btu/hr right?
Thanks,
Brian
Thanks,
Brian
If the women don't find you handsome, they should at least find you handy!
For the info!If the women don't find you handsome, they should at least find you handy!0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
