Old 550 in ground tank, how many inches is absolute minimum?
hh409
Member Posts: 14
in Oil Heating
I was looking to run my old 550 in ground tank to absolute minimum before hooking up my new 275 basement tank. The old 550 is from the 1950's . Typically how far above the tank is the pickup and how many inches of oil would you estimate absolute bottom?
The only way to know....
Without historical data from a run out, is to let run out. Everyone installed them differently, and if there was a water problem in the past, someone could've pulled up the line a little. Typically we install the new tank, fill it, run line over to burner, and run the old tank until its dry. Then do a proper change over.
Along with your other post, if you convert to one pipe, don't forget to remove bypass plugsteve0 -
thanks for the info
got it
thanks for the info0 -
I always
pulled the suction line up about 4" off the bottom. Is the tank stickable?0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
